Ir para o conteúdo principal
My screen does not work after replacing superdrive
I have an iMac 21.5, EMC 2389 model. After replacing the Superdrive with a SSD I have damaged the monitor data cable (APPLE P / N 593-1280 VENDOR: ACON) and has come out a cable wire vertical sync LED card (APN: 593-1237 REV : A VENDOR: LW). The case is now unbootable iMac screen after being turned off, however if it boots the screen when I restart the iMac. Know if these symptoms may be normal for educated the monitor data cable?, Where I can buy these cables?
Thanks for your help and sorry for my English by google traslator.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
3 respostas
Pergunta mais útil
Go here to find your part number: http://www.welovemacs.com/mc508lla.html
Click on the box to the left of this to blow it up: Apple iMac 21.5-inch 3.06GHz Intel Core i3 (MC508LL/A) Parts & Upgrades
Esta resposta foi útil?
Pontuação 2
1 comentário:
ok thank you very much.
por
I believe that the cable that you need is this one. Double check your model number before ordering.
Pontuação 0
1 comentário:
Thank you for your help.
I am not sure that this is the cable that you indicate. I think the smart thing is to bring the iMac repair center.
por
This is the cable you need.
http://www.ebay.com/itm/New-LCD-Cable-59...
Pontuação 0
Adicionar a sua resposta
Joan Recasens será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 1,896
