Ir para o conteúdo principal
Modelo A1502 / processador 2,4, 2,6 ou 2,8 GHz de dois núcleos / Lançado em outubro de 2013
Is it safe to use with the battery disconnected?
I just bought a new Late 2013 Retina MacBook Pro 13", and I want the battery to remain in top condition as long as it can. So I thought it would be a great idea to disconnect the battery to preserve it when I use it home for a couple days.
Any comments/advices?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Lets look at it this way:
  • If you dislodge the power cord, what you are working on will be corrupted so the battery is acting like a UPS protecting your work.
  • Your system was designed to be a sealed system
  • The space internally were the connector is located is not big enough for the connector to be disconnected without long term damage with the cover off or on.
  • Constant reconnecting will wear the connection and if you are not careful you could also damage your system if the unit was not fully off (sleep mode) when you altered things.
Bottom line here: leave it alone it was designed to be used this way.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kiss Zsolt será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 412
