Ir para o conteúdo principal
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is called the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
My controller won't connect
Could you help? I've done as you've said about holding power button and I've got the screen where it says connect controller. My problem that my controller won't connect, I'm using the cable from remote to ps3 but the red lights flash on controller and it goes off. Also I've tried restarting the controller but still the same..
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Carl Stock!
Do you try with another controller?
The symptoms are like your battery (inside of the controller) isn't ok or the USB connector on the controller is damaged or... your controller is broken ):
Regards.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I charged them on a working system and they actually when I go to the other room and try to connect with the super slim model they turn on the older model and connect with it from another room
por
Use the 'new' usb cable :)
Pontuação 0
1 comentário:
I have 5 usb cables , even with it connect to the system it will not pick them up it turns my earlier model on in another room
por
Adicionar a sua resposta
carl stock será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Ao todo: 2,206
