Ir para o conteúdo principal
The screen doesnt work
The screen of my iPod doesn't work, i try to turn it off, or turn it on and it dowsn't work when i connect the iPod to the pc, the pc recognize the iPod touch but the screen is still black, i can't listen to music the last time it worked normally i was listening to music and then it suddenly stopped when i tried to see what was happening the iPod screen was black... :( i don't think it turned off because of the battery, when i was listening to musci i remember that the battery was in 50%
sorry for my english :(
help please i'm desesperated because i'm in bolivia and there's nnowhere i can go to get the iPod fixed, i bought it in france 6 months ago...
thanks
Esta é uma boa pergunta?
Pontuação 1
4 comentários
The iPod charge when i connect it to the computer... i tried to reset the iPod and it doesn't work...
por
does in itunes everything look normal ?
por
yes in itunes looks normal
por
did you try to make a screenshot ?
(press and hold the power button and then press the home button - this should work with firmware 2.x to 3.x - you should hear a shutter noise and after that, connect it to the computer and look inside the dcim folder of the iPod)
por
Adicionar um comentário
1 resposta
Pergunta mais útil
does itunes report any problem or will it connect normal ?
does the iPod charge when you connect it to a computer ?
maybe you should backup your stuff and try to make a hard reset (press and hold the Sleep/Wake button and the Home button for at least 10 seconds - then the iPod reboots) if that won't help - restore it with itunes.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
tim será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 2,310
