LED Backlight not working reson water inside
my macbook air led backlight not working bacause some water get inside of my macbook.
what i do i think its fuse problem how can i solve and from where i buy components
thanks
Esta é uma boa pergunta?
thanks
You should read through the tags at right to know what you're in for, & what can happen if do not stop attempting to use a wet machine, do dissconnect all power and clean the logic board.
Only by examining the board can you determine how badly it's damaged, what other components are lilly to go bad over time without attention.
Start with obtaining the proper tools (every job is easier if you use the right tools). Study (not just read the guide and comments for your particular machine (13" MBA is a very generic ID).
You probably have damaged the controller/fuse for a LED display version MBA… or you may have less complicated, expensive damage on an older model.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 129
