Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
iPhone blocked, only emergency call available
Hi everyone,
Sorry for the long question, but I have an issue with my brother's iPhone 4 (iOS 7), from France (so SIM card, aso). Here is the problem:
- At the beginning, the power button was not working, the screen a little bit broken, so I opened the phone to see what to change and decided to order a power and sensor cable (the screen was not that damaged).
- I reassembled it. We put it on charge in order to power it, and the phone was working as previously (with still the power button not working)
- I don't know why, I re-opened it just to confirm my diagnostic one day later (before receiving the power and sensor cable), reassembled again, but that time the phone didn't display anything when we put it on charge. However, the phone was "working" as we could hear the keyboard, make it vibrate by putting silence mode, aso..
- When I received the power and sensor cable, I replaced it, but after reassembling it together, it was as if nothing had changed: power button not working, nothing on the display when charging.
- So I re-opened it, changed the screen with a working one, tested it, and when opened, I have been able to make work the power button a couple of times (but not everytime I pressed it), and thus put it into DFU (at that time, I hoped it was only a software problem, and not a mainboard issue). The apple went visible. And here is the problem I am now facing:
the screen after the apple is the locked screen, with, written in the middle: "iPhone de-activated" (not locked). and the slide bar shows: "slide for emergency call", and when I slide it, I arrive to the keyboard for emergency call, but that's all.
- I reassembled it, now it is still in the same state, with the power button not working. When I connect it to my iTunes (not the one the iPhone is synchronized with) with my SIM card inside, it recognizes the Phone, and iTunes tell me to acknowledge the computer from the phone, but nothing appears on the screen. the same with jailbreak softwares...
I put the motherboard into a working iPhone, I obtained the same result (screen locked, and only emergency calls available). I put another motherboard in this iPhone, but the power button still didn't work, and at this time, sadly, I was using the display that might not work, so nothing appeared on the screen.
First, thanks and congratulation for having read this story !!
Then, does somebody have an idea on what I could do to fix it?
If I have time, I will re-put a working mainboard into the phone with the working display, to see if I have something different (wich I should).
Thanks a lot for your help, and sorry for the long, very long description...
Have a nice day.
Esta é uma boa pergunta?
Pontuação 2
4 comentários
emergency call only Iphone4
por
I cannot make calls or send message. Its telling me i have no cell servive and im disconnected. As well its telling me that i have no sim card. But i do.
por
yeah , this is happening to me too . I really don't know what to do . and I cant live without my phone . please help .
por
If the issue is still present when changing the sim card, and if there is no mechanical issue when inserting the sim card, then it really looks as if the component that communicates with the sim card is dead. That's a component from the motherboard that is not easily replaceable (need heavy-expensive equipment to unsolder and solder a new component on the board). So, sadly, my advice would be to change the motherboard (and save data before of course)...
por
Adicionar um comentário
3 respostas
Solução escolhida
Hi there,
Thanks a lot for your reply!
Actually, the problem was solved by itself ! A few months ago, I had a look again at the phone, and I just tried again to reinitialize it using basic functions of iTunes, and it worked ! I am wondering if there is not some link with a lock of the phone at least during one year... anyway it worked then by just reinitializing and by also unlocking the phone from the Apple account of the previous user...
Good Luck for your try !
Thanks
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
In my experience, issues like this that "evolve" are frequently moisture related. I would check the liquid damage indicator stickers, pull the logic board and examine very closely for signs of corrosion. If there are any signs of corrosion, clean the logic board with isopropyl alcohol and a toothbrush, then reassemble.
Pontuação 2
1 comentário:
this is your most likely solution as i have seen the same in the past
por
I had the same issue, and given to another mobile repairing shop. They found that the Power IC ( which is somewhere near the battery) is getting overheated while charging and or when switching On. he told me he will try to replace, but there is some risk. Either the phone may get damaged or it will work. Fingers crossed now !!!
Pontuação 0
Adicionar a sua resposta
bcouraud será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 10,300
