Ir para o conteúdo principal
Unable to boot from USB with battery attached
I inherited a 13-inch 2012 MB Air A1369 (1.7 Core i5) with liquid damage. It came without a SSD. After cleaning I am able to boot from a USB HDD with OS X 10.8.2. However when I connect the battery all I see is a blinking question mark on a folder. Disconnecting the battery allows me to again boot.
Do I need a SSD to allow for operation when battery is attached? Are there other problems? Would sending it off for repair be helpful?
Update
I just finished installing a SDD, connected the battery,restored from an external backup and it booted. Weird!
Without a working Power Button an SMC reset is impossible.
Now, to replace the keyboard. Onward and upward.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Connect the battery and try an SMC reset... the machine may be fixated on booting from the HD. Some of the newer machines are a bit idiosyncratic about booting with/without batteries.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
grad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 163
