Ir para o conteúdo principal
The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 Perguntas Visualizar todos
How to unfreeze phone?
While in record mode, my phone has frozen. How do I unfreeze it? I've tried turning the phone off, but nothing happens. I've tried taking the SIM card out, but nothing. How do I take the battery out of this phone? Will that work?
Esta é uma boa pergunta?
Pontuação 165
49 comentários
Thank goodness almost thought I am screwed, you're awesome my phone is my mobile assistant imagine loosing everything as I cant backup every day, jeez thank you for the advise. LOVE YOU!!!!!!
por
It worked, thanks for the help. It's good to have internet
por
thanks it helped ,now its working
por
this helped me my phone was frozen for three hours and i was freaking out it was frozen on a ugly seflie of me thank you so fing much
por
its turned off now but everytime i try to switch it on again, it freezes again on the same screen
por
Exibir mais 44 comentários
Adicionar um comentário
3 respostas
Solução escolhida
Try holding the power button and volume up button at the same time, until the phone gives three short vibrations. Then it will turn off, and you should be able to start it again as normal.
Esta resposta foi útil?
Pontuação 455
254 comentários:
thank god I found your answer, I was already afraid I'd have to completely reset it, since all the other websites and stuff suggested doing so. Who would've thought it's that easy. Really, thank you so much, this saved me a lot of trouble.
(I also casually made myself an account just to tell you about my absolute gratitute hahah yeah)
por
DUDE!!! LIFE SAVER!!!!! It happened to me while taking pictures, Worked like a charm! Awesome!!
por
dude you're awesome ,thanks
por
OH MY GOODNESS THANK YOU!! I took it into Bell today and the guy said i was S.O.L and would have to get a new phone! Its not even a year old! I was furious!!! Thank you SOOO much!!! So much good KARMA please to go your way! xo
por
really it works! it's been 7 hours since my phone stuck up, can't turn off.. and i just did to call my phone until it will become battery empty but i'm so !@#$ tired waiting,, thank you!!!
por
Exibir mais 249 comentários
It didn't work for me but this did (I got this answer from another website)...
All you need to do is a simulated battery pull
A simulated battery pull will simply tell the phone to reboot, to turn itself off and then back on. This simple tool is amazing for a frozen or locked up Sony Xperia, or if your phone is showing a white/blue/black screen, if it’s having navigation problems, or for any reason you can’t seem to power the phone off yourself all you need to do is the simulated battery pull.
To do a simulated battery pull on a Sony Xperia you basically follow the same steps as you would when doing a simulated battery pull on the Motorola Atrix HD, all you have to do is hold the Volume Down button and then the Power key and hold these two buttons down simultaneously for about 15-20 seconds. After holding them down for about 20 seconds if the phone didn’t power cycle then release the keys and try and turn the phone on like you normally would by briefly pressing the power button.
Pontuação 14
13 comentários:
Thank you roxsox, the simulated battery pull was the only thing that worked for me as well.
por
yay now that 3orked ty!
por
Thank you so much I was going so mad that I was ready to throw the phone across the room as I was trying what other people said but that still did not work but thankfully yours did so thank you again
por
Yep that trick with the down button and power worked amazing..because when it froze on FB ..I could do nothing.. it is a sealed unit... I was bit worried.. Thank you
por
The screen comes on but just blue with scrolls wave ....no icons
por
Exibir mais 8 comentários
Your phone screen could be broken, even with no cracks.
You could get it checked and see if it needs a repair.
Not sure…
Pontuação 0
Adicionar a sua resposta
ty gilchrist será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 53
Duração total: 277,456
