screen is out of calibration maybe?
i cracked my phone and just replaced my screen but now when i touck the screen it moves around like the screen is out of calibration but u cant calibrate the lumia 520 but also the screen works fine after i turn it off then back on and i can use it only if its on a flat surface and if i pick it up it messes up again
PS. i have already tried the factory reset it dont work
Esta é uma boa pergunta?
"i can use it only if its on a flat surface and if i pick it up it messes up again" double check your connectors as well as the ribbon cable.
por oldturkey03
im having the same issue but i want to know if there is any way i can fix this asap
por Charles
