Ir para o conteúdo principal
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Display not working after replacement
I just replaced the display. I plugged it in and it worked. Removed it, installed the digitizer and replugged the display and now the display won't come on
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
Try a reset. Hold down the power button and the home button simultaneously until you see the apple logo. If this doesn't work, you likely blew a fuse. You can google the fuse locations and replace it or bridge it with a bit of solder. Good luck!
Esta resposta foi útil?
Pontuação 1
Hi,
Wait until the battery is discharged. This can happen if you remove the display before power off the device.
Regards.
Pontuação 1
Adicionar a sua resposta
Eddie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 172
