Ir para o conteúdo principal
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Perguntas Visualizar todos
upgrading MacBook Pro 17
I just got one on eBay my first mac… I'm going to update/upgrade a lot. I know I can put a 1tb ssd hard drive in it but can I put a 2tb hard drive in it. Is it worth putting i7 chip in it or should I keep the i5 chip in it. If anyone has any more things I should do let me know and I'm putting 16gb ram in it with a blu-ray player. Thanks PS I don't know if or what airport card it has. So what's the highest/best airport card for it and thanks again.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
You can't change the chips on most laptops - they are professionally soldered to the logic board. You could put a complete i7 logic board in it, however if you have a 17" 2011 MBP it is already an i7 - they made no i5 17" machines ''.
Max the RAM to 16GB ,
The best airport card is the one currently in it - you can not upgrade to 802.11ac
All of these MacBook Pro models support a 2.5" notebook hard drive or SSD that is up to 9.5 mm tall (0.37 inches) and use a SATA interface, but the maximum SATA interface speed of different models varies, look up your specific machine.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Justin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 263
