Ir para o conteúdo principal
Guias de reparo e informações sobre como desmontar Macintoshs (Macs) da Apple.
42811 Perguntas Visualizar todos
Pergunta encerrada
How to fix a stripped screw?
OK. On my MacBook 13'' which is broken, many of the Philips #00 screws are stripped. I try to turn them with slightly bigger screwdriver that has worked for them in the past, but the screwdriver just doesn't grip the screw hole. I don't have a dremel, nor do i have super glue easily on hand. what do i do?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I literally tried EVERYTHING. I tried the rubber band trick, holding down on the top of the screwdriver, i even tried a hammer to push the magnetic screwer in the void of the screw. NOW WHAT?!?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Depending on how stripped the screws are, you may be able to put a rubber band between the screw and driver to see if it can give you some grip.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 330
