Ir para o conteúdo principal
Model M7572 / 400 or 500 MHz G3 processor
45 Perguntas Visualizar todos
Will not boot up despite active power soure
I have tested the power source and it works well. I plug it in and press the on/off button and nothing, not even a faint noise, occurs. Everything seems dead. From past experience what is the most likely cause and is it worth trying to find a fault and repair it?
William
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
On board dc-in circuit, faulty power button/damaged top case. If someone has been in it before you they may not have completely or correctly reassembled it.
It will take a lot of troubleshooting, examination to determine where the first or major problem lies. If the battery is charging that could eliminate the DC-in board as suspect.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
william isbister será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 131
