Ir para o conteúdo principal
login, then freezes/hangs with a blue screen - why?
When I turn on the computer I can log in and then it hangs with a blue screen and a search icon in top right you can still move the mouse and if you hover over the search icon you get the spinning colour wheel. Any ideas?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Solução escolhida
You could have a full HD, a corrupt font, bad extension, preference or file.
Boot from your repair disk. Verify your HD and repair permissions.
Verify you have 20% free space on your HD (if you have a 10GB disk you need 2GB empty for Vmem and swap files)
From your install disk make a new user account at boot to it. If that works you have corruption someplace in your old account. You should very carefully move over files and fonts (not apps) from that account (move a couple and restart) you do not want to re-import the bad data.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
If the wheel keeps spinning and you can continue to move the mouse around, chances are you're dealing with a dying hard drive. And if the laptop eventually completely freezes up and you can no longer move the mouse, that points in the direction of a bad logic board. The third possibility is a corrupted OS install, or a system that is so bogged down it can't successfully boot up. Try booting in safe mode by holding down the shift key immediately after hitting the power -- booting with minimal resources may improve the laptop's ability to get through the boot sequence.
Yet another possibility is that it doesn't have enough RAM installed to boot. Have you ever witnessed this computer working, or has it been this way ever since you've had it? If it has booted up in the past with the amount of RAM installed, then this is not likely the problem. But if it's been stripped of RAM and therefore only has the 128-256MB on the board, that might explain it struggling to boot up.
The best way to proceed is to wipe the drive and see if it will let you reinstall the OS. If that works, you can write it off as a software problem. If you hit roadblocks during the install process, it's likely either a bad drive or board.
If you need to save your data before re-installing, you can put the machine in target mode by holding down "t" while powering on and connecting it via firewire cable to another Apple computer. The hard drive icon should appear on the desktop of the other computer, and you can then copy files over.
Pontuação 2
Adicionar a sua resposta
JennyCoad será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 175
