Ir para o conteúdo principal
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Perguntas Visualizar todos
Change Logic Board from 2.8 to 2.66 GHz
Is it possible to switch the logic board in my 2.8 out with a 2.66 without problems... ? If there are any issues, what should I be aware off ? Hope you can help! All the best Carsten
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
As long as its within the same series of system (size & year) when they where released (i.e. MacBookPro5,1) it should be possible. Generally its best to stay with the same board the system came with (for resale value)
May I ask why you are going to a less powerful board?
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks Dan. Well it's just as an alternative :-)
por
Adicionar a sua resposta
Carsten será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 65
