Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Can not power on after replacing power button
my iphone 4s was having problem with the power button, i have to press very hard to get it to work. i got a replacement power button flex cable and replace it. but after the replacement, the power button completely stop working. I swap back the old cable/button, its not working either. What could be causing this? thanks
  • it does power on after i plug in the cable to the computer.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
There are a couple of issues. A couple times I have looked at this issue it ended up being that one or both of the screws on the power button retaining bracket were not installed. Does the button make clear clicks when depressed? It shouldn't be hard.
Check your cables for folds, tears or rips. Check the port the cable plugs into for dust, debris, or broken solder points. Is this phone still recognized by iTunes?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
cli168 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 79
