Ir para o conteúdo principal
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
cooling impeller makes too noise...
Hi
I've follow your instructions and changed the HD to my mac mini...everything was perfect...but now the cooling impeller give me a lot of noise....It always runs and take out a lot of air...It never stops...
What did I do wrong ?
Thanks in advance..
Fabrizio
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Pergunta mais útil
Well it could be because the temperature sensor was disconnected from something (maybe the HDD). When I replaced my HDD with an SSD (Which had no aux port for temperature) my computer reports my HDD to be 128 degrees Celsius. To check if its the temperature thats making the fans run at 100%, you should download iStat Pro or iStat Mini
iStat Pro
iStat Nano
Esta resposta foi útil?
Pontuação 1
1 comentário:
good +
por
Adicionar a sua resposta
Fabrizio será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 1,175
