How Can I Fix Hard Drive Data Loss Problems
Have you any answer of this problem, so please share the link - Urgent Need!!!!!!
Esta é uma boa pergunta?
If solve this trouble then you need to use best data recovery software that will help you to fix that problem without any issue.
Esta resposta foi útil?
There are some issues like HDD recovery and problems of bad sectors in the HDD etc are increasing around users. There are many Hard Disk Recovery professional service providers available in market and can be approached easily.
at first you should try to make an image of your faulty hdd and then
try to recover the data from the image.
every try to recover data from original faulty disk can cause more damage to the disk.
For an instant solution to recover lost data from Windows System, you can get the help of Kernel for Windows Data Recovery software. It is very advanced and affordable third party software that helps you to recover deleted or lost data from corrupted, damaged, or virus-attacked Windows FAT16, FAT32, NTFS, and NTFS5 partitions. To get more details, visit: http://www.windowsdata.softwarerecovery....
Seems like it’s too late for the answer but still, if you need to recover files from the hard drive, due to some issues you can use Uneraser from Diskinternals. That software will help you to recover any kind of files.
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 712
