Ir para o conteúdo principal
headphone jack on logic board broken
I shomehow broke the headphone jack on the logicboard on my iPod mini 2nd gen. Is there a way to soilder it back on..?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
maybe - where did what get broke ?
if the connector on the logic board fell off - then maybe
if the headphone jack has gotten defective on is little board - sure, can be replaced
so give us a few more informations about the defect and we'll find a solution
Esta resposta foi útil?
Pontuação 1
The headphone jack is a modular part, so you can easily replace it with this part.
Also, check to make sure that the connector is seated correctly on the board. If the connector itself is broken, then it may be possible to solder it back on if you're careful.
Imagem de Replace a dirty, corroded, or damaged headphone jack for an iPod mini.
Produto
iPod mini Headphone Jack
$9.99
Pontuação 0
Adicionar a sua resposta
bishopx será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 3,024
