light problem in monitor
I have the iMac G5 and the screen is only half lit there must be light tubs of some kind. what kind of bulb is how do I change it and what is the cost
Esta é uma boa pergunta?
even if this looks like another orphan - let's try it:
it could be a inverter problem or one of the ccfl's is dead.
the ccfl is not a simple bulb - but replacing is possible - if you have the right part.
to rule out the inverter - i can only recommend this posting from richdave: What part number and how do I replace the backlight?
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,329
1 comentário
Would you describe the problem in greater detail? Is it the top or bottom, is it gradual? Did it happen slowly or all at once?
por mayer
