Ir para o conteúdo principal
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
iPad Mini Home Button not working after digitizer replace
I replaced the digitizer on an iPad Mini and now the home button doesn't work. Not to be mistaken for the issue where the home button thinks it is always pressed. It is not responding at all. Anyone??
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
4 respostas
Pergunta mais útil
Have a look at this thread: iPad Mini Home Button Not Working After Digitizer Replacement
the answer was given by GtechRepair: "The easiest solution Is to go back to the old screen at the bottom where the Home button is located, There you will see two pieces of fabric tape, The one closest to the home button will be layered over a clear piece of tape, try to remove them together, use x acto knife to lift up corner, then a good pair of tweezers to peel it off.
Perform the same procedure To the fabric tape to the left, Then place both pieces down on your new digitizer, In the same place that they were in on the original. This should solve your problem 100%."
these black tapes go here:
Esta resposta foi útil?
Pontuação 2
Same here :(
Pontuação 0
1 comentário:
Im going to try a new digitizer assembly when I can. Have you tried this?
por
Same issue
Pontuação 0
NICE.. SWEET! (If only I hadn't thrown that old broken digitizer away :(
Pontuação 0
Adicionar a sua resposta
Gavin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 3,638
