Ir para o conteúdo principal
Repair guides and support for water softening systems.
How to repair a water softener?
Is there a repair manual for water softener? Our's is a PRO Series E E-70.
It just cycles won't turn on, release the water.
Esta é uma boa pergunta?
Pontuação 3
3 comentários:
Crystal, that is a ProFlow SA-PRO-E 70? what cycles and what won't turn on?
por
The tank comes on and makes a lot of noise as if the water was cycling through ; however, it never stops and water never releases.
por
Water pressure drops from time to time in the kitchen faucet or bathroom shower
por
Adicionar um comentário
2 respostas
this might help
http://docshare01.docshare.tips/files/12...
Esta resposta foi útil?
Pontuação 0
The incorrect regeneration cycle of your water softener might be caused by a number of factors. This includes an inadequate supply of electricity, a power outage that resulted in an incorrect setting of the clock, and a broken timer. Replace the damaged components to make the cycle functional once more.
Pontuação 0
Adicionar a sua resposta
Crystal será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 1,235
