Ir para o conteúdo principal
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Perguntas Visualizar todos
data and text work fine. Can not make or receive phone calls
I can send and receive text, google questions, even replay voice mail. phone calls do not come in or go out.
all else works
Esta é uma boa pergunta?
Pontuação 130
35 comentários
Am I supposed to swipe before answering with the green icon?
por
did any one find out how to fix this
por
With my phone everything works but when I call someone I can not hear them and they hear this loud high pitched noise. I know it is not my microphone because I can still call on messenger. The same thing happens when I receive a call from someone.
por
My samsung s4 works completely fine at times but sometimes when i make a call it wont go through. The other person will get a call but it will be silent and neither will i be able to hear anything. It continues like this unless i restart my phone. I had this problem with my last samsung so i bought a new one. Please help
por
I had the same issue. I turned off the noise reduction feature and I was able to make & receive calls immediately.
por
Exibir mais 30 comentários
Adicionar um comentário
20 respostas
Solução escolhida
Hi Neal,
First, restart your phone by holding the power button for 10 seconds. Make sure free calling apps like Viber, Tango or Skype isn't your default calling app or simply uninstall these free calling apps.
You should also check your call settings. Open the phone app -> tap on Menu -> tap on Call settings - > then scroll to the bottom and choose "Use Internet Calling" under Internet Call Settings. Make sure that "Only Internet Calls" is selected. I hope this will help you.
Esta resposta foi útil?
Pontuação 39
10 comentários:
I was looking around under- Phone Dial Pad ----> Menu ------> Call Settings ------> Noise Reduction (I turned this setting off and it seems to have solved the problem..... for now, haha )
por
Thanks Barrett. Turning off the noise reduction feature worked for me as well!!! Thank you soooo much!
por
Thank you so much this worked. You are my lifesaver I was ready to cry
por
Beware! My S4 could send / receive texts, download from internet, four or five bars (reception), but still couldn't make or receive calls. To make more confusing, my wife could make / receive calls on her iphone with same carrier (att.) Spent hours trying to resolve, then finally went to ATT store. Now could make / receive calls! Turns out, ATT tower by my residence had GSM voice outage (her phone cdma), but neglected to tell any of the customers in the area. So before you begin the quest to fix the phone, get the phone out of the immediate vicinity and see if it will make calls. Hope this saves someone some aggravation.
por
What if im not in range of any wifi network this isn't a solution.
por
Exibir mais 5 comentários
I had the same problem, tried all the above. I could only use the phone in Wi-Fi mode.
I powered down the phone several times with no success.
Finally, I shut off phone, removed battery and sim card, waited a few minutes and then
replaced them. when I turned on the phone the problem was resolved.
Pontuação 7
11 comentários:
Thanks, this worked for me. and it was a simple solution and it makes me wonder if the other more complicated ways to fix this could simply be bypassed by this method. I was not able to make calls for three days, after removing the battery and replacing it (I forgot to remove the Sim card) it worked again as usual.
por
worked for me too. Thanks to you.
por
That was the only thing that works for me too I had to shut off my cell phone shut off my watch and I remove the SIM card from my cell phone for about 5 minutes turned it back on and I could receive calls and make calls from my watch with no problem thanks for the help
por
So simple and solving the problems all at once. Thank you so much, Maria!
por
But what to do with phone having non removable battery like samsung A20?
I can have text messages in and out ,and all internet services but no phone call in or out ,and all this has been all of a sudden
por
Exibir mais 6 comentários
I found the problem with my phone. I can get data, internet, text, but no voice phone. It turned out to be the radio antenna for phones calls. The grey wire on the right side was getting pinched when I screwed the back on. I also lifted the usb flex circuit board slightly, from the right. Cleaned the contact between the board and the antenna contact on the frame and pressed it back. That fixed it. So, check your grey wire connections or try replacing the wire.
Phone radio has a different antenna than wifi, 4g, Bluetooth. Etc.
Pontuação 7
4 comentários:
where do you get the gray antenna?
por
After the screen repair, data worked but no calls... I've opened and and I didn't connect the white coaxial cable on the right...
Now they are working
por
I got My New phone but i can't make calls or recive calls please help
por
How do I get filter block off my phone
por
I was having problems receiving and making phone calls. No calls were coming in and I couldn't make any calls. The dialer would timeout and no calls would ever go through. After looking through the threads on this I noticed many people had the same issue mostly with Samsung phones. So I thought it was my phone as I have a Samsung Galaxy 6. I also happen to use my old iPhone 4 as an iPod in the car or with earbuds and I noticed that lately it was showing up with missed calls. After reading the threads with no ideas given on how to fix the no call issue I decided to try test. I have always left me iPhone 4 in my car right outside the garage and back door of my house so after retrieving the iPhone from the car I turned it off and restarted my Samsung Galaxy 6. After doing this I was able to make and receive calls again! Hallelujah!! This is happened to me with a Galaxy 4 and the Galaxy 5 and I could never find the fix. It would just start working later on and I never knew how or why it started working again. So to recap if your phone will not make or receive calls check and make sure you do not have another Verizon phone somewhere that you used to use that is turned on. I cannot be sure but I think it's just this iPhone 4 that I have since it doesn't have a SIM card that has been giving me problems. I hope this help someone as I found this extremely frustrating and had it happen to me on several different phones. I would hate to think that someone would go out and buy brand new phones, waste their time at a Verizon store, or anything else when my problem was very simple to fix.
Pontuação 7
4 comentários:
I have same problem but no old phone laying around to mess with so I got a new sim card from tesco didn't help I bought a new phone 2nd hand as under contract still does same thing I erased all data and accounts and reinstalled it still no luck been a month now and my phone won't work
por
I have the exact situation happening..have u found any solutions? The only thing different is it worked for a few days and now it just says searching for service constantly even though I checked with the carrier and I have complete coverage in this area.
por
I have AN LG android. It has none of the things google says to check. Maybe T Mobil can fix it for. Lose to 100 a month they should. Cannot call have go in. Joy!
por
I was having an issue. I had inquired about a free phone service from Qlink. They give out free sim cards and no phone charges. Well, I got one, I had to unlock my phone from Verizon. Did all that, put the new sim card in my android cell phone. Wasn't able to make or receive calls or texts. Found out FROM Qlink that my area is bad for service. I knew that, but I figured I'd try it anyway. Weird thing is that even though I wasn't able to make calls, my phone still showed at least 2 or 3 bars. In my case it was just bad service on Qlinks end. Once I put BACK the original sim card, everything went back to normal. Tracfone only charges me a little less then $14 a month with unlimited calling and text.
por
This worked for me and haven't had any more problems dialing out. Take the back off, remove the battery, unplug the SIM, replace everything.
Pontuação 6
3 comentários:
I can't get the back off or remove the sim card!
por
I am not able to remove the battery from my phone...
por
I have to go through six buttons on my phone to get to my contacts and to make a phone call I don't know what the problem is and I've owned his you know what my phone is I'm speaking on right now I bet T-Mobile I've got the Galaxy store I got Google and I don't know what am I my I got to go in his early &&^&@@-up situation why can't I just turn my phone on unlock it and the phone that I can download my contacts to be right there but I really &&^&@@ up situation thank you
por
Your problem same with my phone.. You try type *#06# your IMEI no will appear on your screen.. I believe..your screen will appear ( invalid ) that's why your phone can't call in and out..this is your h.phone problem..not your sim.. You can put your IMEI no back and make a call in out normally.. Follow this step to put IMEI on your phone.. Take your IMEI no at the battery area normally, or get it from your HP box...if your hp have a 2 sim you must be a 2 IMEI no..copy that and follow this step..
1) type *#*#3646633#*#*
2) choose Connectivity
3) choose CDS Information
4) choose Radio Information
5) choose phone 1
6) you can see AT+ on your screen.. Just add E and your screen will appear AT+EGMR=1,7,""
7) put your IMEI no between "" for example :
( AT+EGMR=1,7,"123456789" )
8) don't forget you must modified a little bit things, just put
the "space" between AT+ for example :
( AT *put space here* +EGMR=1,7,"123456789" )
9) and push button SEND AT COMMAND
10) on your bottom screen will appear
(AT command is mSent) in 3-4 second.
11) if your HP have a 2 simcard you must have a 2 IMEI no
12) to put second IMEI no just follow step 5 and choose
"Phone 2" after finished setup 1st IMEI at the same time
13) follow step 6 and choose ( AT+EGMR=1,10,"" ) and follow
the step until step 10.
14) after finish the setup just restart your HP
15) after restart type *#06# and your IMEI no will appear,
and your phone will be OK. If not working send your HP
to your hp service centre..TQ..GOOD LUCK.
Pontuação 3
6 comentários:
My sumsung galazy tab 4 cannot make or receive call
por
The only problem my phone has, i can use it to call and receive internet calls but i can't use to received call.
por
I have a android phone it wont let me make calls or receive calls and has a treangel at the. Top of scrine
por
Tried doing this but it didn't work. But my phone is detecting 2 difeerent IMEIs at first even though I only have 1 sim. After doing those steps and dial *#06#, I'm still seeing 2 IMEIs but they are now the same but I can't make or receive calls still. Any other suggestion?
por
After dialling #06# i get the error "requested service unknown".
Please help
por
Exibir mais 1 comentário
I went to the chat settings on the top, turned noticications on and asked the person whom I wished to call to do the same thing, and boom it worked! hope this helped since I was having the same exact problem.
Pontuação 2
1 comentário:
I had the same exact problem, what I did was go to the chat settings, turn notifications on, and asked the person whom I was trying to call to do the same, and boom it worked! I really hope this helps.
por
Here's what i did, i turned off my phone, took out my sim card, placed my sim card onto another phone, tried dialling out, and it worked on my other phone
(If it does not work, its the card or your account's problem). I placed the sim card back into my old phone and it returned to normal.
If that doesn't work, you can try the method described on this youtube link:
https://www.youtube.com/watch?v=B4rEUEWp...
If it still does not work, then you can try going to application manager, ALL, Uninstall Google Inc. (Which gives you updates all the time)
If it still does not work, you may have to reset it to factory settings.
Finally if it still does not work, then i am afraid you will have to bring to to Samsung branch to get a technician to take a look at it.
Hope this helps!
Pontuação 2
Pontuação 1
1 comentário:
That's what finally worked for me (after shutting down thr phone for ten minutes, then rebooting it first).
Not sure if this matters AT ALL, but the phone was on the charger the whole time.....
por
Just turn phone off for a minute. Everything should be working when you turn it back on.
Worked for us.
Appears to be a. AT&T problem, because my husband has a different phone and we both had the same problem at the same time.
Pontuação 1
1 comentário:
Not just at&t I use metro n my son's haveing this issue just after changing phones and he uses zte not Samsung it's just started I'll fix tonight and anyone still need help can I'll walk threw it theirs multiple issues that may cause this but by tomorrow I'll have a fix for zte at least e mail me for help title e mails help with dialer and I'll get back to u, beanjad@gmail.com fwm Droid users
por
Well I had this problem both on iPhone and an android phone,and I solved by turning on "show my call I'd " did this by going to settings--> calls---> then caller ID ... this setting should be in network default as some networks don't support turning off your caller ID status
Pontuação 1
Hello
I was unable to make calls from my Samsung Galaxy Tab A. ..but i can receive all calls..I am using airtel 4g sim..it was also well working in my ordinary 2g mobile..need a help please .. .
Pontuação 1
1 comentário:
I unchecked as many things as I could that were not important. Then I turned phone off and then back on. Then it started working!!!!!
por
I tried all of the above with my Motorola phone with Verizon service, except removing my battery because it isn’t removable. I finally got the dialer working by going into the call dialer settings--> calls---> voice privacy ——> and unchecked the box marked “Enable enhanced privacy mode”. It worked. I then researched this function and decided it was more trouble than functional. So I am leaving it unchecked. Very odd.
Pontuação 1
Hi. I recently switched to a new phone and was having a similar problem after trying to activate it. Everything seemed to transfer over just fine, but for some reason I couldn’t make or receive texts or calls. I found this forum while looking for a solution, and even though it’s kind of old, I just thought I’d share what eventually worked for me in case it helps anyone else. After trying a few things on my own and having no success, I called customer support and what finally worked is when she asked me to reset my network settings. After I did that, texting and calling started working just fine. I reconnected to my Wi-Fi network and thankfully it’s all working good now.
I’m not sure why my network was interfering with making calls and texts at first, but if this sounds like your issue try going to Settings—> About Phone then go all the way down to where it says “Reset”. From there go to Reset Network Settings. Hit the Reset Settings button and confirm. Try making a text or call. If it works, all you have to do is reconnect to your Wi-Fi and you’re all good! Thanks and hope this helps!
Pontuação 1
1 comentário:
I getting no network connected i call company still cant figure out whats the problem why?
por
I just fixed the same issue … I went to setting … app … and reset app preferences
Solved immediately
Pontuação 1
1 comentário:
ive been trying to figure this out for so many days, probably a week. this worked
por
here is the full guide > https://xdarom.com/phone-wont-make-calls...
Pontuação 1
I had this problem, finally I understood that the problem is about Contacts. just do Contacts Disable and Forcestop, then everything will work. the only problem is Contacts app.
Pontuação 1
Find call text on this device
Pontuação 1
So none of the above worked for me until
Go to Apps… then three dots top right corner… App Permissions
Then scroll down and click on Telephone and make sure only the following are allowed
Contacts,Messages and Phone
Took me over a week of pulling my hair out to figure as nothing else worked at all and was ready to buy new phone. Seems something had updated (probably google) and took over my calls. Hope that helps people
Pontuação 1
Recently resolved same issue its easy
Go to sitting developers option then activate the 3GPP AT command (on)
Then you can receive and make calls.
Pontuação 1
Adicionar a sua resposta
Neal Dunn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 35
Últimos 7 dias: 214
Últimos 30 dias: 895
Duração total: 798,522
