Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Pergunta encerrada
How to permanently disable wifi
Want to disable WiFi but still be able to make calls and send text. If I remove the WiFi antenna and do not replace it, when reassembled (without WiFi antennae)will I be able to still make/receive calls and text messages? Do not want to just temporarily disable WiFi. I need to remove and permanently disable it. Thank you for any assistance you can provide
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
That should permanently disable wifi without interfering with any other functions of the phone except for bluetooth because the wifi and bluetooth antenna are one part. If it does happen to interfere with something else, you can always reinstall the wifi antenna.
Esta resposta foi útil?
Pontuação 1
7 comentários:
Thank you! Your help is appreciated
por
I tried this and I still have wifi without an antenna! How is that possible? What else can I do to disable wifi?
por
I am trying to disable wifi on an iPhone 4.
por
Just because you disconnected the antenna doesn't kill WiFi services (or any other service you pull the antenna) it only limits the range of the signal.
por
I don't know of any way to permanently disabling WiFi here other than disabling within iOS its self. Maybe if you explain why you need to do this we could try seeing what options you have.
por
Exibir mais 2 comentários
Put a restrictions code on it believe me he won't find a way around it if is entered wrong to many times it locks him out of phone
Update
Or look for a iPhone 4s with greyed out wifi forsale these are going really cheap
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 6
Duração total: 5,998
