Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
20 Perguntas Visualizar todos
Pergunta encerrada
Can you replace/ upgrade the logic board?
I have a Mid 2009 MacBook Pro 2.26 GHz and I wanted to know if it would be possible to get another logic board from a 13" MacBook pro mid 2012 or late 2011 and put it in my mac. Would the logic boards fit in the enclosure? Should I go with a logic board without thunderbolt? would i need to replace the screen or isight camera to get it to work?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
No - the logic boards from newer models will not match up, you'll likely have display problems also (graphics cards and connectors are different).
You can use either of the '09 boards.
If this answer is acceptable please remember to return and mark it.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 155
