Ir para o conteúdo principal
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
472 Perguntas Visualizar todos
On the spin cycle machines vibrates excessively?
Machine vibrates excessively when in spin cycle either with or without clothes in washer. Already checked adjustments of feet on bottom of washer and they are in correct adjustment and locknuts are tight.What will cause machine to vibrate excessively in spin cycle and clothes are in balance?
Esta pergunta é pertinente?
Pontuação 12
6 comentários
Where is the suspension spring located.? The top of the drum is very loose and wobbling back and forth. I read another blog which said to check all the springs. Of which there are 4. The three at the base are good and in place. I can't locate the forth which is supposed to be to the back. I can't seem to find an illustration showing the springs.
por
I think I found it, but all springs appear to be in good condition. Any other suggestions?
por
Are the springs in balance? My springs can hook into a series of slots to pull the tub one way or the other, and I fixed the balance by moving to different slots.
por
If washer vibrates without clothes in it , most likely the inner drum spider is broken.
por
what is an inner drum spider?
por
Mostrar mais 1 comentário
Adicionar um comentário
9 respostas
Solução escolhida
Support Bracket
Washer vibration can occur if the support bracket is broken. Check the bracket for any damage or wear, replace as needed.
Shock Absorber
Washer vibration can occur if one or more of the shock absorbers is broken or worn out. Check the absorbers to be sure they are installed correctly and in the right position. Sometimes when a washer is moved the shock absorbers separate and have to be put back together. If they are broken or worn out, replace all at the same time.
Suspension Rod
Washer vibration can occur if one or more suspension rods are broken. Check all four rods, replace any that are broken.
Suspension Spring
Washer vibration can occur if one of the suspension springs has broken. Check all of the springs, if any are broken replace all of them at once.
Counter Balance Spring
Washer vibration can be caused by a broken counter balance spring. This washer is equipped with one or more counter balance springs which help to absorb the natural movement of the spinning tub. If a counter balance spring fails the tub might lean in one direction more than another and it will shake and cause vibration. The springs can be replaced but before purchasing the spring check to see if the place the spring attaches is OK. Sometimes the frame where the spring attaches has rusted out, making the repair more difficult and expensive.
Snubber Ring
Washer vibration can occur if the snubber ring is worn out or cracked. Replace as needed.
Snubber Pad
Washer vibration can occur if the snubber pad is worn out, missing, or coated with anything sticky. Replace if it's worn out or missing.
Snubber
Washer vibration can occur if the snubber is worn out. If the snubber is worn out replace it.
Balance Ring
If the washer has excessive vibration, the balance ring may have lost its fluid. The balance ring sits on top of the outer tub and helps to counter the force of the spin cycle. If the fluid leaks out of the balance ring the washer tub will be too heavy for the suspension system and cause the machine to vibrate and shake.
Drive Block
Washer vibration can be caused by a worn out or broken drive block or bell. The drive block connects the transmission with the agitator, if it's loose or broken the agitator can wiggle back and forth during spin and cause vibration
Rear Drum with Bearing
If the washer has a bad vibration in spin the rear drum with bearing might need to be replace. On this washer the bearing is not sold separately, the entire rear drum will have to be replaced. This is a very involved repair and will require disassembling most of the washer. However, if this is the problem it is going to get worse very quickly and so either the drum and bearing will need to be replaced or the washing machine.
Leveling Leg
Washer vibration can occur if one of the leveling legs is out of adjustment. Using a carpenters level on the top of the machine, be sure to adjust each leg until the machine is level side to side and front to back. Once the machine is level, tighten the lock nuts, if equipped, on the leveling leg threaded bolt against the body of the washer to keep them from changing height.
Esta resposta foi útil?
Pontuação 20
4 comentários:
How to replace suspension rods on washer
por
replace the WASHING MACHINE MOTOR CARBON BRUSHES
por
elliott would you elaborate on this?
por
how do you replace the snubber in the model 110 washing machine, where can you get a repair manual.
Pontuação 2
1 dos comentários:
I will let you now if you helped
por
This Qasis model does not have any torque springs, rubber snubber, or balance ring that could see. I'm thinking the stator mother is causing the excessive vibration. David V.
Pontuação 1
This would be helpful if there was a diagram to go with it as you list out the possible problems.
Pontuação 1
1 dos comentários:
it's pretty simple. Copy and paste the parts he listed on YouTube or Google and you will get more info and how tos and diagrams then you need.
por
www.repairclinc.com has repairment parts. They also have how to replacement videos.
Pontuação 0
I just fix mine 110 kenmore was on the spin cycle vibrates excessively . I make the mistake before. I put the pin though the hole of the skate plate. When I took the pin out and be sure that skate plate was free and the right place. I start my machine in spin cycle and work fine.
Pontuação 0
1 dos comentários:
through no though
por
How can i tell if the rod or springs are out on my washer? The tub is detached fron the top of washer
Pontuação 0
When it was a new washing machine, the master set it up and it did not vibrate. After a while, the nut on her leg gave way and I tightened it myself and set up a text about it https://www.diyany.net/the-washing-machi...
Pontuação 0
I had this problem for some time. Not knowing what to do, I finally called a machine repairman. He came, told me it would cost $175 to fix, then did it. It has worked perfectly for the past 3 years.
Pontuação 0
Adicionar a sua resposta
Bobby Jambon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 38
Últimos 7 dias: 231
Últimos 30 dias: 1,135
Duração total: 236,588
