Ir para o conteúdo principal
Pergunta encerrada
Replacement screen has stopped working
Good morning
I recently replaced a cracked screen on an Iphone 5, I've done a couple in the past and it seemingly all went ok with no issues for about 5 days until I got a phone call saying the display had gone black. I thought it could of been a fault with the new display but I changed it back to the old one and it doesn't seem to work either. A couple of other thing seem to happened to phone the display stopped working too:
- The phone doesn't seem to vibrating when i switch it to mute
- The volume cannot be turned up or down
- Siri responds with "there is something wrong and i cant answer your questions at the moment, please try again in a bit"
- The digitizer seems to work, as I can swipe to answer calls
Looking at the phone I couldn't see any tears in the cables or any other damage so I'm really at a loss as what could be wrong with it. Any help as to where to begin would be great. Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
I would start with a full cleaning and the repair water damage guide found here. Not that is water damaged but it wouldn't hurt. The full disassembly may reveal a poorly connected flex or two.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 178
