Ir para o conteúdo principal
Repair guides and support information for Lenovo's G series of laptops.
165 Perguntas Visualizar todos
"WIFI" AND "BLUETOOTH" not working in my lenovo laptop
im using my lenovo 3000 G430 laptop recently im facing a problem..!
wi fi and Bluetooth in my lappy dont never turns on.
i tried a method posted in the web but it doesnt work (i.e. BIOS setting and turn the SATA to IDE)
curent os windows 7
can anyone provide me a better solution????
Esta é uma boa pergunta?
Pontuação 18
3 comentários
i have also this problem
por
i think just update the driver in wireless and reset the setting will help you
por
plz rply me e46l driver which model same driver
por
Adicionar um comentário
10 respostas
Pergunta mais útil
click start-> search for Device manager -> find your bluetooth and wifi adapter and enabe it [it is mostly in network adapters section]
If it is already enabled :
click start-> search for Device manager -> find your bluetooth and wifi adapter -> Right click and uninstall the device driver [NOTE- do not delete the driver software] -> Restart your device [your device driver will get installed automatically]
If still doesn't help, try updating drivers .
Thanks
Esta resposta foi útil?
Pontuação 5
3 comentários:
Thanks a lot. This worked for me guys!
por
Thanks a lot. Worked perfectly and so simple.
por
thankyou so much bhaaaaiiiiiii bahut time ki problem tumne solve kar di thankyou so much
por
for fixing the wireless issue with lenovo try these steps too-
1. just reset the wireless adapter go to device manager and check the wireless driver
2. try updating the wireless driver and uncheck the power management from wireless adapter option
3.if nothing works just uninstall and remove the old wireless driver and settings and download the latest drivers . check the firewall settings and make sure nothing is blocking the internet . for more letest updates and drivers help visit http://support.lenovo.com/us/en/ and i hope this works for any other issue just let me know
Pontuação 4
It there a little switch or button to turn them on ?
Also you may need to install the most recent drivers for WiFi and Bluetooth
Pontuação 3
There are several issues that cause it to stop working, recognizing them timely and acting to fix is the key to overcome such annoying problems.
Restore Windows to the last working configuration:
If your Wi-Fi has just stopped after installing any new software, then it would be better if you could try restoring your Microsoft Windows back to an earlier copy. If any recent installation is stopping your Wi-Fi from work, then you should better roll back Windows to an earlier system restore point that will surely work for you.
 Reinstall the wireless drivers:
Sometimes, corrupt drivers are the real culprits. If your laptop is a victim to these issues, it won’t detect any internet network. Such indicators reflect issues pertaining to the corrupt drivers. Therefore, it’s better to reinstall the drivers in an attempt to fix the network problems.
Pontuação 2
Use the Fn and F5 key together. The Wifi/Bluetooth dialogue window will open. Enable both in it, Voila ! Your problem is solved.
Pontuação 1
2 comentários:
In case you are unable to use it, ask me for the screenshots.
por
Can you add screenshots on how it is done?
por
Make sure that when putting in the password for your wifi it is correct. Re start your wifi and select new, then re-try it, hope this helps.
Pontuação 0
When your laptop won’t connect itself to the wifi, there can be several reasons for this issue.
* wifi is weak.
  • driver or network issue.
  • Settings issue.
These are the two most common reasons for Lenovo laptop wifi not working issue. now here are the steps to fix this issue.
  1. put your computer nearby your router, and restart your laptop.
  2. change the wifi encryption and then try to connect again.
  3. Let’s update the wifi driver on your Lenovo laptop, and then try to access your computer again.
  4. Factory reset your laptop, and configure it again.
Pontuação 0
how can you update if you cant use wifi
Pontuação 0
You need to remove what I believe is a defective RealTek WiFi card and replace it with an Intel AX200NGW WiFi. I did that and have never experienced another WiFi issue. I never used Bluetooth so I don’t know whether my solution solved the problem. Lenovo would never own up to the defective part so I just purchased the part myself and installed it. Although it might appear to be that the wires from the WiFi antenna have been compromised, I assure you that is not the problem.
Pontuação 0
Wifi chip remove an clean to reinsert!!
some time wifi an bluetooth signel wire probleming you can change the signal wire to fix it
To use easy driver Software to update your driver proper driver software !
Pontuação 0
Adicionar a sua resposta
Daddu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 53
Duração total: 77,420
