Ir para o conteúdo principal
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Perguntas Visualizar todos
Pergunta encerrada
Completely dead after failed iOS 6 update attempt
After repairing a friend's broken screen iPod touch, the device got the common but fixable "white screen error." (What I mean by this is the screen is completely white, but it is detected in iTunes and makes sounds when locked or plugged into a charger, etc)
I usually restore when this happens and it's fine, but this one got stuck in the "extracting iOS data" status, so I left for a while. When I came back, the iPod wasn't detected in iTunes, and it was unresponsive.
Now it appears to be completely dead. It won't respond when connected to my PC or a charger. It is not detected by my computer or iTunes, and of course trying to enter recovery mode or DFU mode does no good either.
I left it plugged into a charger for a good long while to make sure battery power wasn't an issue. The iPod was bought new by my friend, and never jailbroken. It had iOS 5 on it prior to the restore attempt.
I find it troubling that an iOS update error could completely kill an iPod. Is there anything else I could try?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It is very difficult to kill an ipod touch without physical abuse. The device has a hard-wired DFU mode that cannot be destoryed by just updating the software. So boot into DFU
mode to tre installing the system again
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you! It took a couple tries but eventually I got it into DFU mode. I don't think I was holding the power button long enough. Simple answer, but saved me a lot of grief!
Thanks again.
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 195
