Ir para o conteúdo principal
Pergunta encerrada
no display on start-up
I have just replaced the keyboard, hard disk and memory on my laptop. However when I try to reboot I get a blank screen, I have pulled it down again to check all connections were ok, but same response - any suggestions.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hook up to an external monitor to see if the GPU is OK. Why did you replace the parts you did and was the screen working before you did so?
Esta resposta foi útil?
Pontuação 0
Hi everybody.
Same problem on my Macbook Pro and i do not have a screen on the external monitor also :(
Mainboard or GPU broken?
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,256
