Ir para o conteúdo principal
Repair guides and support for the Acer line of netbooks including the Aspire One series.
20 Perguntas Visualizar todos
Pergunta encerrada
BIOS problem and laptop is not starting
My Acer aspire one D270 laptop is not starting. The screen is not showing anything i.e,. black but the power indicator remains ON and the fan stops after some second.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Try starting it up with the battery removed, and the charger attached.
It might start. If not, if it does even less than before, then it points to the possibility of a dead charger.
If it does the same thing then try holding the power button for about 20 seconds.
You can try re-seating the memory modules as the contacts get dirty.
If none of this works it points to a failed motherboard or CPU.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,021
