Ir para o conteúdo principal
The RIM BlackBerry Curve 8520 is a sleek entry-level smartphone that delivers some nice design enhancements and great performance
x on the signal bar with any sim card
with original sim card or any other sim card there is an x on the signal bar, so i am presuming that the signal receiver is broken. i have opened up the backberry and im looking at the chasis or the motherboard. Where is the signal receiver and what does it look like?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Couple of things:
First, I read your previous question and I'm not convinced it is an antenna fault. However, to answer your question the antenna looks like this and costs about $2.00.
Second, I believe, if it is a hardware issue, that it may be the SIM card reader itself. If that is the case you may need a new logic board.
Third, the little "x" in the signal area usually means that it is still actively searching for a signal, but is not in range of one. So it is possible that since you were changing settings for unlocking the phone that it is searching for a signal that is is out of range of. If this is the case it means your hardware is all perfectly fine and you have a software (settings) issue.
Esta resposta foi útil?
Pontuação 1
hello i have cell phone blackberry curve 8520 icant type keyboard thank you.
Pontuação 0
Adicionar a sua resposta
kayleigh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 634
