Ir para o conteúdo principal
The Nexus S is a smartphone co-developed by Google and Samsung was the first smartphone to use the Android 2.3 "Gingerbread" operating system.
My Phone is dead, now it is not powering on.
I tried to charge my battery of my nexus s from another local charger. . . but it made my phone dead.
when i check supply pins of phone when positive and negative of battery comes in contact with device's pin with my external power supply and power it on. .
it doesn't power on. .
I took my cellphone to repairers to get it checked. they told me it's problem of power ic
I myself is a electronics engineer. so please guide me it is exact problem of power ic or something else. .
Hope, my post will be seriously taken into consideration.
Esta é uma boa pergunta?
Pontuação 3
1 comentário:
i have this problem too..if u have any solution so plzz tell me....
thnkxx!!!!
por
Adicionar um comentário
3 respostas
If your power IC is dead then you'd have to either replace the entire board or become a robot and solder on a new one. HOWEVER, try this: take out your battery, put it back in, hold both volume down+volume up and plug in a USB cable. If your phone boots into download mode then all is not lost! Here is a new motherboard if you're intent on fixing this phone (provided it is a Sprint Nexus S), or swappa has a phenomenal array of smartphones for cheap.
Cheers,
tabormeister
Esta resposta foi útil?
Pontuação 0
chake this
https://www.facebook.com/pages/Dead-sams...
Pontuação 0
same happened with my phone i did what you said not working
Pontuação 0
Adicionar a sua resposta
Subhash será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 18
Ao todo: 3,301
