Ir para o conteúdo principal
The Nokia E71 is a smartphone from the Eseries range with a QWERTY keyboard targeting business users worldwide. It was released in 2008.
How to get the cover off Nokia E71 to remove dust
Is there a good way to pry off the front cover so that you can dust off the screen underneath. Worried about cracking some connectors if I go about it the wrong way. Pretty tight fit and not sure if it is designed to be taken off.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I hate to just Google it for you, but I Google'd it for you. Here it is :
Nokia E71
Regards,
Frank
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thanks! (Feel really stupid.....)
Good photo guide. Note: you will need one of those special octagonal screwdrivers (the tiny ones) to undo the screws in the second picture
por
"special octagonal screwdrivers" - it's called Torx - the size in that case was T4 ;-)
por
Look for this procedure:
Disassembling Nokia E71 Complete disassembly
Pontuação 1
Adicionar a sua resposta
Tze Wen Leow será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 12,061
