Ir para o conteúdo principal
Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
iPad 2 adhesive does not stick to frame!
Hello!
I need some help!
I just replaced my digitizer. My adhesive does not stick on two of the corners (Down and top left corner) and almost to the home button (from corner to home button). I just do not want to open it up again. So i wonder if I can just use super on therse places and let it dry upside down?
Or is it other possible ways to fix it?
Thanks!
Erlend
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Glue does not work because glue need a rough surface to adhere too and glass is smooth. use 2 sided tape everywhere there is a edge, you may have to tuck the glass digitizer ribon in to not cause a spring effect so glass does not come up on the lower left.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Erlend será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 197
