Ir para o conteúdo principal
The HP Pavilion dv9000 series was introduced in 2006.
51 Perguntas Visualizar todos
No Sound, Driver doesn't load
I gave dv9900 with windows vista, it gets really hot and the sound driver doesn't load, it worked a couple times when I restarted the system to factory settings, now I tried it again and it just doesn't load the sound
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
julio, "it gets really hot" is way more of an issue than the sound driver. I suggest you open up your laptop, clean the air vents, clean and check the fan and replace the thermal paste on your CPU. After that re-evaluate your computer for any real damage.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Julio será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 129
