Ir para o conteúdo principal
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Perguntas Visualizar todos
Replace LCD flex without separating LCD and digitizer?
I found a tear in the flex cable for the LCD while doing a repair on the i545 verizon galaxy s4. Before I start taking the front assembly apart is there anyway to remove the cable without having to seperate the glass and digitizer from each other and the case?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
short answer is, You broke your flex to the LCD and the flex is not repairable well at least for the average joe. Its best to buy a new LCD display.
Esta resposta foi útil?
Pontuação 0
How would you replace the flex cable? I'm not an average joe
Pontuação 0
You can't. Once that cable is broken, it's broken. Move on and get a new lcd.
Pontuação 0
Adicionar a sua resposta
Charles Warren será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,949
