Ir para o conteúdo principal
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
The Error is nand flash media is keepout : 688 physical nand Block..
Hi,
i Need help how to fix it?
Need your guides how to fix it, my ipad warranty is expired. according to apple repair this item cannot repair need to replace 1 to 1. since the warranty expired than i need to up the money MYR 1,300.
Please guide me what should i do?
it's logical board? its flash problem, or something else please advice.
Thanks
Esta é uma boa pergunta?
Pontuação 2
7 comentários
Ouch! One of your flash cells clearly is burnt. Have you gone to an Apple Store? I would try again as this should be covered under warranty.
por
Thanks Dan,
Yes, but apple store advice me this no covered under warranty (since warranty is expired ) they told me that this not allowed to repair unless from factory and they asked me to buy the new one. to exchange i must to pay MYR1,300 for replacement.
can flash cells be repair or change the board ? any advice?
thanks
por
I'm sorry but this item is 1 year and a few months old? damage to nand is not something you'd expect from normal wear and tear and therefore not caused by you. I'd contact Apple again. Be pushy, write emails, ring them. There are people who'd be able to replace this but finding them is the problem. good luck
por
Thanks pollytintop for your advice-
I’m still keeping looking forward how to fix it. Will not this item (ipad) throw become rubbish due to damaged that do not know cause and cannot repair or fix it?
Hope somebody highlighted this issue to Apple (the best customer service ).
Thanks
por
Exibir mais 2 comentários
Adicionar um comentário
6 respostas
Solução escolhida
Sorry to say to repair this will require a new logic board. You just can't replace the flash chip due to how the logic board is designed (SMT). And it will be costly! Not really economical to repair.
If you tried desoldering the chip you will likely disturb or damage other components as they are so tightly packed. While not quite the same layout you can review Step 13 in the iPad2 teardown to get an idea on how things are laid out iPad 2 Teardown. Frankly I haven't seen this flash chip available as a replacement chip from anyone (you can buy sticks of a 1000 units from the manufacture). Which makes even the thought pointless.
The error condition is clearly a flash cell failure that can't be remapped by the onboard controller to a different cell (likely all of the spare cells have been used). This is a part defect nothing you could have done in the short time you had your iPad that could explain this.
You really need to contact Apple (up the food-chain) to get this fixed. Don't take no as the answer here from the front line people speak with the the service manager at the Apple Store then the store manager and if that doesn't work press them to speak with someone higher.
Make sure you have as clean a system (no dirt buildup) and if you don't have one get a case with a cover lid. Also make copies of your receipt of purchase of your iPad or your bank statement (if you don't have the original receipt). Black out your bank account info and other charges and what you have in your account (You don't need to tell them how rich or poor you are). If you used a credit card same thing, but I would give them the last four digits of your card.
Also check with your local government on what your laws are for warrantee coverage. In some countries they have longer periods of mandatory coverage.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks Dan for your info and advice.., to confirm that logic board replacement. I will take risk buy and replace the logical board and will update you thanks
por
Pergunta mais útil
Its 100% Not the Logic Board. I have repaired over a dozen iphones and iPads with Nand Flash errors at bootup. This is a Hardware related failure. You need to strat disconnecting each flex cable individually until you figure out which flex cable is defective. On the iPhones its usually the Proximity Sensor Light Flex Cable.....
http://www.etechparts.com/Proximity-Sens...
On the iPads its usually the interconnection Board flex cable...
http://www.etechparts.com/Interconnectio....
I have repaired this Nand Flash error over a dozen times with 100% Success..
Hope this helps you guys out....
www.StevesiPhoneRepairs.com
Pontuação 3
1 comentário:
I replaced the proximity flex/front camera, and now it just shows another code which is shown below. Any advice?
[NAND] _FindFlashMediaAndKeepout:601 physical nand block offset 1
[NAND] start:356 this 0x864e2400 PROVIDER=0x84bcff80 flashMedia=0x84bcff80
[NAND] WMR_Start:149 Apple PPN NAND Driver, Read/Write
[NAND] WMR_Start:174 FIL_Init [OK]
por
http://www.apple.com/support/ipad/assist... try this or http://support.apple.com/kb/TS3274 ? or this https://discussions.apple.com/thread/512... try charging fully and then connecting to itunes whilst holding home button,http://forums.macrumors.com/showthread.p...
Pontuação 1
Unhook the daughter board run ipad off just the logic batter. This error is possibly a bad daughar not completely sure yet but this worked. After Ipad boots up fine hook it back up and it should work!
Pontuação 0
2 comentários:
this is a quick fix , but when you hard reset it goes back to the code
working on other solutions for this problem i'm thinking the whole daughter board itself or a cable plugged into it possible the one that runs to logic board on/off or rear cam maybe something is shorting out on daughter board for sure though
por
the one I was just working on I replaced just the flex and it has totally resolved the issue It is the flex cable runs over the battery and connects the logic board and daughter board
por
I Recently had this with an iPad 3, it turned out to be the rear camera that was causing this error and draining the battery, after replacing the rear camera, its all working again, as Steve iPhones said above, its best to disconnect all flex cables and you will find it will most likely boot up, make sure your battery reads at least 3.6V or it will not boot. iPhoneBits
Pontuação 0
1 comentário:
Glad i could help my friend. I see this Nand Flash error a lot. Troubleshoot it by disconnecting flex cables one by one and booting up until you find the culprit....Then replace the flex cable causing the problem. I have fixed over a dozen iPhones and iPads with a Nand Flash error........Great to hear it resolved your problem!!!!!!! Steves iPhone Repairs
por
Is there some place I can send my iPad II and get it repaired? I get the same Nand errors as listed above but I am not knowledgeable about iPads enough to repair it myself.
Pontuação 0
Adicionar a sua resposta
biggles será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 90
Ao todo: 21,119
