Ir para o conteúdo principal
The Linksys WRT54G (and variants WRT54GS, WRT54GL, and WRTSL54GS) is a Wi-Fi capable residential gateway from Linksys.
impossible to get connection with Ethernet network
How to set the hardware factory settings router Linksys model VTR54GL v 1 . 1
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
3 respostas
Solução escolhida
Here's the Linksys support page for your unit WRT54GL Wireless-G Router It has all you should need to answer your questions.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
You must connect to the router via Ethernet cable for setup/upgrade. If you pooched the upgrade buy a new router... software fixes/hacks are not really our thing here.
If this Answer is helpful please remember to return and mark it Accepted.
Pontuação 1
Esta resposta foi dada inicialmente para uma outra pergunta.
Try by resetting your router and re-configure it again. Please note that your all saved setting shall gone once you have done hard reset so i would suggest if your using ADSL then get your PPPoE account setting from your ISP first and then do this.
Pontuação 0
Adicionar a sua resposta
Oghi Boev será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 221
