Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
2193 Perguntas Visualizar todos
Backlight problems and battery problems
My brightness goes off if I turn it down past halfway and it randomly goes off in the most inconvenient times and is very hard to make out what is on screen this happened after soaking my iPhone 4S and having to replace the battery. and when my phone dies it does at 4 percent every time now and won't let me know that it is charging when I plug it in its just a black and blank like its still dead like its not doing anything at all leave it plugged in long enough it magically comes back on at 4 percent.
Esta é uma boa pergunta?
Pontuação -1
6 comentários:
Please help its not critical but I want to know what the !@#$ the problem is thanks
por
Did you check for corrosion on the backlight coil and IC?
por
No will this cause worse problems in the future in gone unchecked?
por
Yes the auto brighness is off
por
Yes, it could if it is corrosion. I suggest a good cleaning with isopropyl alcohol and a soft brush.
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Check and see if the auto adjust brightness is on, If it is turn it off.
hope this helps
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ben Lake será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 154
