Ir para o conteúdo principal
Small plate around rear facing camera
There is a small plate that goes around the front facing camera. (shown next to step six in the manual) There is no reference to this, is it a toss away with the cracked front screen or should it be removed, cleaned up and reused?? And I don't see it in the photos of the screen assy. Thanks in advance for your response(s).
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Hello!
I believe you are referring to the metal plate on the right of the front facing camera?
I think you will struggle to find a replacement one of these anywhere so I suggest hanging onto it :)
A tip for the future, do not dispose of any parts unless you are confident you know exactly what it is and will never have any use for it :)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mike Woodruff será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 68
