Ir para o conteúdo principal
Liberado em abril de 2010 com as opções de processador i5 de 2,4, 2,53 GHz Core ou i7 de 2,66, 2,8 GHz Core
590 Perguntas Visualizar todos
Trackpad not working after keyboard cleaning.
This morning I lightly wiped the keyboard, trackpad, and palm rest area with a sanitizing wipe - something I've done many times over the years.
My trackpad now does not work properly. The cursor skips across the screen in small steps when trying to use the trackpad, and will drift when left untouched.
I have tried resetting NVRAM (cmd opt p r) and removing the Finder preference files, but I get the same behavior - this is all I could find that was self-help related...
I removed the trackpad from the frame and inspected the connector cable and wiped all corners / edges of the frame and trackpad - still no go. Same results as before.
Keyboard works fine, as does an external mouse.
AppleCare is now expired (must be only a couple days outside of warranty)...
Before I spend $90 on a replacement trackpad, I'm looking for a way to confirm that the trackpad is indeed the issue.
Thanks.
Esta é uma boa pergunta?
Pontuação 6
Adicionar um comentário
6 respostas
Pergunta mais útil
How long have you waited since you cleaned it?
I have this same issue when I wipe my computer down with water or any other computer product. The issues is that excess water gets along the sides of the trackpad, and similar to using your phone underwater, it thinks you are constantly touching the trackpad in every corner. I usually let the trackpad dry out, but somethings it helps if you take a piece of paper, stick the edge in between the trackpad and the palm rest, and run it around the sides of the trackpad gently. You might see the paper gets wet. If it does get wet, just use another corner and go around again. This should work.
If the problem still occurs, then you might want to take out your battery and see if there is any water under the trackpad. If nothing works, let it sit for a day or two, that normally will fix the problem.
In the unlikely case that you did damage your trackpad, you may need to replace it. I have had this same issue though on MacBooks from 2006, to MacBook Pros from 2013, and either drying the sides with paper, or letting it sit always works.
Hope this Helps
Esta resposta foi útil?
Pontuação 6
3 comentários:
Thank you Owen.
Using a sheet of paper to wick moisture away / out of the crevices is a good idea. Even after 12 hours the trackpad was still acting up.
I was not clear above, but when I mentioned wiping edges of the case and trackpad, that was with a soft dry cloth hoping to pull out any wetness.
Interestingly (to me), there was no moisture / wetness to be seen or felt.
When I got home I pulled the trackpad again and swapped it with my wife's MacBook thinking this would tell me what parts, for sure, I needed to order.
Her trackpad works fine in my machine, and my trackpad works fine in her machine.
Also of note, this process allowed me to adjust the click sensitivity on her machine, which has always driven me crazy.
Thank you for the ideas.
por
The paper corners helped my track pad improve. Takes a while and slot of sheets. I took thick scotch tape applied and smoothed over trackpad. Roped up fast. Got some of the gunk off it. Helped some. Also. I used corners of thin plastic sleeves u put basketball cards in or etc. used after paper. Little former to maybe get any remaining debris out
por
Thanks you so much I got a school computer for elearning and I wiped the track pad and had this problem I did what you said and it worked
por
You do need to be careful what you use as well as how you clean the trackpad area. Water based cleaners will leave a film and they can creep under the edge of the trackpad causing it to go haywire until the water dries out! In some cases killing it altogether!
  • Never spray anything on the screen, keyboard or trackpad.
  • Don't use wipes! They are often too wet & can be harmful to your system electronics.
  • Wipe up ASAP anything that spilled on the keyboard or trackpad and turn off your computer until you can get to someone to clean it professionally.
Best to use a high quality isopropyl alcohol (85% or better) and the most important trick here is to use just a little on a cloth (lightly dampened) then wipe the trackpad and the rest of the case. If doesn't come off with the isopropyl alcohol use distilled water again a little goes a long way on the cloth.
Pontuação 4
Blast the trackpad with a hairdryer for a minute or two.
Works like a dream
Pontuação 3
6 comentários:
If you don't spray the system directly with the cleaner you won't need to do this.
por
Hair dryer was a great idea, worked like a charm!!! I did it after trying the paper and using a q-tip & water to wipe off any residue and dry with a Q-tip. Hair dryer took few seconds worked great! Note: This was all within 5 to 10 minutes of my keyboard acting up after a clean and looking for answers.
por
Worked Brilliant! I signed up only so that i could THANK YOU. Saved me
por
A minute with hairdryer worked magic!!
por
Sounds like you got cleaner caught under it. Best to spray the cloth and then wipe Vs spraying the case and then wiping.
por
Exibir mais 1 comentário
I also have the same issue, i don't get it! I've cleaned it dozen times already.
I noticed that track pad goes a bit grazy, but never like this and never for this long
What should i do?! :S
Pontuação 0
3 comentários:
This exact problem for me too with Lysol wipe. Retina pro early 2013. What did you end up having to replace?
por
Did the same thing, the trackpad wouldn't stop making false clicks and moves. Plugged in an external mouse, moved it around a bit, then touched the trackpad and moved that around a bit and saw that it was tracking fine. Unplugged the mouse and everything was good again
por
You likely got some of the cleaner wicked into the layers of the touchpad. This is often caused by spraying the clean directly onto the case. Instead spray the cleaner onto your towel and then wipe down your system.
por
My trackpad was jittering like crazy. The symptoms persisted even while the mouse was plugged in. Touching the trackpad made the cursor stop but it would not move.
From what others put I thought that there maybe was some water trapped somewhere so I took the trackpad out and put it into some rice and baked it at 100F 130 F with a digital thermometer in a hot spot to monitor the temps closely. This seemed to work miracles because it's fully working as of now. I considered the trackpad dead and tried all other options first.
I think the problem was caused by cleaning with rubbing alcohol that was 70% and not 91% by accident.
Pontuação 0
1 comentário:
por
Mine broke too, I wiped it with alcohol and it completely died… If so, then how to disinfect computer during this coronavirus, especially now that my sister keeps on going out and using my computer?
Pontuação 0
1 comentário:
You likely got some of the cleaner wicked into the layers of the touchpad. A wet wipe should be squeezed out of the excess cleaner. You don't need a sopping wet cloth or wipe to disinfect.
por
Adicionar a sua resposta
SergeantSpam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 30
Últimos 30 dias: 143
Duração total: 83,711
