Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
How do I fix an intermitent screen problem?
The top 1/4 of the screen will show legibly, but with multiple missing lines. The bottom 3/4 is dim with many fine lines. When I reboot the device it sometimes comes back with good display. Sometimes not. If I wait a few hours to days, it will come back on it's own. Note that the device will still sync to computer and play audio even when the screen is malfunctioning.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Mabe that your display pixels are dying, or mabe is it just the connector. In any case, if your device is still under warranty (I obviously don't think so for a 5th gen iPod), bring it back to the closest Apple Store Genius Bar.
Then, if it is not, I recommend you to own a new display. You will easily be able to replace it yourself by following the following links.
Hoping to have helped you !
Vincent
Imagem de Replace a broken or damaged color display for your iPod Video with this part.
Produto
iPod Video Color Display
$29.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jeff será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 104
