water coming out of the top of the k-cup holder
I had the same problem, but the paper clip did not work for me. I have water coming out of the top of the k-cup holder and drips everywhere. Any one had this problem, if how did you fix it?
Thanks
John
Esta é uma boa pergunta?
8 comentários
I cleaned my Keurig-Elite and now when it is heating the water it leaks out of the k-cup holder. Any suggestions?
por harpholm
Yes... if you are using a reusable (refillable) K-Cup and your brewer is pouring coffee out badly - missing your mug - splashing and making a mess - leaving grounds in your cup - there is an easy fix on ebay for $5 and it's guaranteed or your money back. Paste this link in your browser:
https://www.ebay.com/itm/171557357690
por Dennis Gaudette
It drips in warm up cycle...ON PURPOSE. Very irritating, especially if you don't have drip tray in place because last user was a travel mug. Poor design.
por crpl_hicks
We had this happen to 2 of our keurigs at the same time, when the house was dryer. As it turns out, the little silicon topper/seal that is mounted AROUND the upper needle (it makes a seal with the top of the coffee pod) had been compressed / pushed up too high. This was particularly notable using NON-keurig coffee pods. Removing it and pushing it back on to where it's just above the needle hole solves it for a while, but a washer/spacer would work better (3-d printing two of them as I type this).
por Steve Arnold
Mine was clogged at the bottom. I thought the seal on top was the issue so I pressed the lid down more when trying to brew and the pressure pushed out the blockage. I dont suggest doing this, as I did not know the true issue, but something to check also when trouble shooting the problem.
por FastforwardX32
Exibir mais 3 comentários
