Ir para o conteúdo principal
Repair guides for the MacBook.
3787 Perguntas Visualizar todos
Why does my mac keep making this weird noise?
My MacBook keeps making this weird noise when I turn it on or open it. I think its the fan but I'm not so sure because I also think its the battery. Does anybody know what it might be?
Esta é uma boa pergunta?
Pontuação 1
7 comentários
Can you describe the noise better? Ralph
por
I got it too. It repeats several times until it starts loading.
por
i am facing the same problem with my Mac book pro which is two years old. Please let me know what to do . only difference is that the noise rare and it happens while opening the mac book.
por
I have the same problem please help me out how do i fix it now....
por
@mailes - Smick you'll need to give us more than this. You should also create your own question as this one is quite old.
por
Exibir mais 2 comentários
Adicionar um comentário
5 respostas
Solução escolhida
Normally the Book will try to access the optical drive first. (whirring noise), Then it goes to the hard drive (sometimes a clicking sound). A squeeking noise can be made by capacitors going bad. Fans can make a screeching or chirping noise if going out. It all depends on the type of noise, and the location. Is this a new noise? Remove the battery and start up with just the AC adapter connected to eliminate it first. As rj asked, a better description is needed to help you.
Esta resposta foi útil?
Pontuação 4
1 comentário:
+ Ralph
por
I just looked up "reason Mac would start making noise on start up" and found this thread! My new Mac (got it about 5 months ago) suddenly started making a noise on start up that seems to be coming from the right-hand side where the DVD player (sorry can't think of what it's actually called) is. It sounds like it is starting to play something or moving- hard to describe otherwise...like vvrmmm...vrummmm (lol), like switching back and forth. It never used to do it and I'm a bit worried because now it does it with every start-up. I don't believe I've ever used the player part before either.
Thanks for any help
; ) Danette
Pontuação 2
Get a ROBLOX account, play prison life 2.0 WITH a hacker or just have crappy wifi, play a different game, get triggered hit the computer as hard as you can until it goes away
Pontuação 2
2 comentários:
yo cheers for that one, i started to it my laptop and it actually fixed it!
por
LMAO XDDDDD that might work
por
because you keep squishing it thats why its making that sound
Pontuação 2
2 comentários:
Oh yeah when I pressed down on the bottom left corner of my Macbook Pro it makes the clink sound. Thanks
por
yes i do beat up my macbook regularly
por
lol just BUY A NEW MACBOOK PEOPLE
Pontuação 0
Adicionar a sua resposta
Cynthia Pena será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 49
Duração total: 30,521
