Ir para o conteúdo principal
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
Why is my PowerBook blinking a black question mark and smily face?
hey when i turn on my
PowerBook G4 Titanium DVI Model A1001
it shows me a white screen for 2 minutes then shows me a black question mark and a white and blue smily face what do i do?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Your machine can't find a valid operating system. This can be caused by a corrupted system folder or a failed hard drive. Boot from the original system CD holding down the "C" key and start to install a system, the second screen the pull down menu appears. Go to Utilities. Open "Disk Utility" and see if you can repair the drive. If you can see the drive and disk utilities doesn't fix it then try installing a new system. If you can't see the drive then you probably need to replace it.
Esta resposta foi útil?
Pontuação 1
1 comentário:
i have the same problem but i dont have the original system disc. is there way to this this with out the disc?
por
Adicionar a sua resposta
luis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 283
