Ir para o conteúdo principal
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
Pergunta encerrada
Building Extra LiPo Mac Battery
I want to buy some Lithium Polymer batteries off a website and solder a mag socket power switch (the Standard Mac Power Plug) to it. I'm assuming I will need a 5 Cell battery because the voltage would be 18.5V
Is this true? Can I just make a backup battery for, say, on an airplane or in a car?
Thanks!
Esta é uma boa pergunta?
Pontuação -1
1 comentário
Thanks for both replies!
Well, I've been talking to my dad about it and so far it seems I will need about 5 Amps at 18.5 volts which would be great for a 5000 mAh 5 Cell LiPo with a 10C rating. Not too much in terms of the actual battery, but it should be able to give about 1.6x the capacity of the laptop's battery.
It will cost over $100 to do, so I doubt I will do it, but if I do, I will post it!
por
Adicionar um comentário
2 respostas
Solução escolhida
To me something like this dc to ac adapter for autos and airplanes would make more sense, but I'm sure you could make such a battery. To me the problem would be housing it and recharging. Good luck whichever way you go. Ralph
http://eshop.macsales.com/item/Kensingto...
Esta resposta foi útil?
Pontuação 2
2 comentários:
The unknown factor would be any circuitry in a normal battery. Ralph
por
After conducting some research on how the MacBook Pro AC power adapter works, I have concluded that building a custom LiPo battery pack would not be significantly cheaper than buying from a 3rd party (specifically a HyperMac battery). The reason for this is because the AC power adapter outputs 16.5V for normal operations and switches to 18.5V for intensive tasks. Building a custom external battery that could do this would not be cost-effective. Also, I believe there may be some differences in current draw when the MacBook Pro is charging vs. 100% charged.
por
Here we are two years later...I have not done it, but E Rogers did, for under $60.
http://www.theverge.com/2012/4/2/2905463...
Pontuação 0
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 2,950
