Ir para o conteúdo principal
Liberado em abril de 2010 com as opções de processador i5 de 2,4, 2,53 GHz Core ou i7 de 2,66, 2,8 GHz Core
590 Perguntas Visualizar todos
New screwdriver required for HD replacement?
I ordered the new 15" MacBook Pro and a seperate Intel SSD (the stock BTO ones from apple are more expencive and inferior). Now I read in the teardown that Apple is using some kind of new screw. Will I need to order a special screwdriver now, so I am ready when my MBP arrives?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I've really enjoyed my 54 piece screwdriver set from iFixit: [produto vinculado ausente ou desativado: IF145-022]
It has everything I've needed to work on Mac screws including the new tri-wing.
If you just need the one tri-wing driver,
Here's one on eBay for $3.95 and free shipping:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vie...
Esta resposta foi útil?
Pontuação 2
1 comentário:
Research + Ralph
por
I'm in the same boat as you - I need to put the 8GB from my 13" into it - really dont want to have to get the tri screwdriver just to open the bottom case.
The manual says you can still remove / change the HDD and RAM, so I guess those are still phillips
http://support.apple.com/manuals/#MacBoo...
yay!
Pontuação 0
Adicionar a sua resposta
konstantin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 6
Duração total: 5,850
