Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
How to Unblacklist My Device?
I purchased an Iphone 4 from gamestop and tried to get a quick prepaid service on it , and was denied because the phone was blacklisted. And being dumb I threw out the receipt smh ....Is there anything I can possibly do to unblacklist it ???
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
5 respostas
Solução escolhida
First check it here for black listing: http://www.imei.info/iPhoneBlacklistChec...
If it is indeed blacklisted, take the report to Gamestop (they should have a copy of your receipt) and demand your money back or a replacement iPhone. You did use a credit card to buy it, right? You can also report it to the police but if you are still in possession of it, you will probably have to give it to the police as stolen merchandise.
Esta resposta foi útil?
Pontuação 2
You could contact your service center or the network provider.
Imei Track
Pontuação 0
try imeiesnrepair.wix.com/imeiesnrpair I repaired my iphone 4s ,not sure if they do 5 or 5s
Pontuação 0
1 comentário:
I used UnlockBoom service to unblacklist my iPhone. It worked fine for my verizon iPhone 4s.
por
yes I have the same problem
Pontuação 0
i have a iphone that i bought off a family member and it is blacklisted i need to be able to get a cheap fix on this please help
Pontuação 0
Adicionar a sua resposta
Matt T será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 20
Ao todo: 23,258
