Glue or not glue? iPhone 4 glass
I have a glass and LCD from iphone 4,
My question is, Glue or not glue? LCD on glass.
Esta é uma boa pergunta?
The glass and LCD are fused together. I don't think that it's glue, but I could be wrong.
If you read this question it should clarify some things.
Esta resposta foi útil?
yes glued, you can use a transparent uv glue. not so easy!!!
a cheap and simple way is to glue the back of the LCD or use a two sided tape. Then glue or use two sided tape on the glass, above and bellow the LCD area.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 229
1 comentário
I was thinking of just gluing the corners, if broken again is more ease to repair.
por nobatente
